vasketsov_serg
Dec 01, 2017Aspirant
Does ReadyNAS 214 support HGST Ultrastar He10 HUH721010ALE604 with Power Disable feature (0F27454)
Hi! HGST Ultrastar He10 HUH721010ALE604 has 2 partnumbers: 0F27606 -Without Power Disable feature 0F27454 -With Power Disable feature Does ReadyNAS 214 support both items or only 1st hdd? ...
- Dec 06, 2017
Hi vasketsov_serg!
WD101KRYZ is listed in HCL for RN214 and basing on the WD spec sheet this drive does not support Power Disable Feature.
It would still be better if you can get in contact with WD support regarding part numbers since it does not show on their spec sheet as well and to verify if PD is a feature for this model.
I hope this helped you.
Regards
vasketsov_serg
Dec 06, 2017Aspirant
Sorry.
I'd like to ask about Western Digital WD Gold 10 TB (WD101KRYZ) - it is another available HDD in our city and in HCL.
I can't get no satisfaction information about PD feature in original datasheet:
https://www.wdc.com/content/dam/wdc/website/downloadable_assets/eng/spec_data_sheet/2879-800074.pdf
Are there many different partnumbers for single WD101KRYZ with different PD options?
Can I use WD101KRYZ with ReadyNAS 214?
Thanks.
Marc_V
Dec 06, 2017NETGEAR Employee Retired
Hi vasketsov_serg!
Regards
- vasketsov_sergDec 06, 2017Aspirant
Thank you very much, Marc_V!
