toonfan
Oct 29, 2012Follower
duo v2 help/advice needed
im new so first off sorry if im in the wrong place, i formatted my readynas duo v2 and ticked the delete volume(i think thats what it was called) on powering it up all im getting is the blue power lig...
Oct 29, 2012Guru - Experienced User
Why did you think you needed to delete the volume??? You should have been finished when you "formatted" it (which initializes the RAID array).
Erase volume takes quite a while (it does a secure erase).
One option is to simply let it finish. Or you could attempt the factory default procedure again. The process is here: http://www.readynas.com/kb/faq/boot/how ... o_2_duo_v2
