gmeier03's avatar
gmeier03
Duo V2 Partitioned 1TB USB HDD?
Just set up my new Duo V2 and tried copying media files from a WD 1TB USB 3.0 HDD FAT32 to the nas through one of the rear USB ports. It didn't mount so I plugged it into the second rear port then the front port, both of which didn't mount. With it still plugged into the front USB, and without thinking, I pushed the backup button. To double check the drive I tried mounting it to my MacBook and it wouldn't mount. Using the Disk Utility I found that the FAT32 partition is gone and there are now 2 small EXT partitions on the drive. I didn't think the Duo V2 could format a USB drive but by pressing the backup button could it have tried to backup the empty nas drive and corrupted my FAT format? The drive spins up when plugged into the nas so in a last ditch effort I tried to force a backup from the front USB to the nas and that didn't work either. Pretty frustrated I had about 800GB of movies on there that I'm assuming are gone.
  • did you see your USB 3.0 device plugged info in Dashboard?Please confirm compatibility of your device on ReadyNAS first,a thing you need to know is that current linux kenel doesn't support USB3.0 very well.can you post kernel log here?
    Something the marketing materials would never admit :twisted:
    We support USB3*
    * There are now (2) USB3 devices on our HCL!
    Some one tell me Duo v2 Kernal EOL. Is true? Do please update kernal too new one too fix USB bug.
  • No, it never showed up on the dashboard before the added partitions or after. I'll check the logs but since I've done a factory reset so the original issue won't be logged. I had another issue with ReadyCloud not working either and called Netger support about it. They did the factory reset. I'll post my claim number when I get home.
  • My case number is: 20925750
    Below is the logs of me removing and reinserting the drive in the front USB then trying to force backup from front USB to the Media share.
    Apr 10 14:41:18 nas-BE-FC-A8 kernel: usb 1-1: USB disconnect, device number 2
    Apr 10 14:41:23 nas-BE-FC-A8 kernel: usb 1-1: new high speed USB device number 3 using ehci_marvell
    Apr 10 14:41:23 nas-BE-FC-A8 kernel: scsi3 : usb-storage 1-1:1.0
    Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:0: Direct-Access WD My Passport 0740 1003 PQ: 0 ANSI: 6
    Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:1: Enclosure WD SES Device 1003 PQ: 0 ANSI: 6
    Apr 10 14:41:24 nas-BE-FC-A8 kernel: sd 3:0:0:0: Attached scsi generic sg1 type 0
    Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:1: Attached scsi generic sg2 type 13
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Spinning up disk....ready
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Write Protect is off
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Mode Sense: 47 00 10 08
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Assuming drive cache: write through
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sdb: sdb1 sdb2
    Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Attached SCSI disk
ProSupport for Business
