utelme
Mar 03, 2017Aspirant
Fan Failure on ReadyNas Ultra6
Hello, I have 2 Netgear ReadyNAS storage units today I recieved an email telling me that the Fan2 in the device is failing with low RPM
I called the store I purchase this device and they told me because it's 6 years old I cannot get a replacement fan through them. So I though I would see what can be done to correct this issue. I am hoping I can get a fan so I don't need to purchase another device as it's still working just one of the fans have failed. Any suggestions appreciated.
- JennCNETGEAR Employee Retired
Hello utelme,
What is the current firmware version? You may also try getting to the FrontView, click Status then click Health. You should see Calibrate button for the fan.
I also strongly suggest to back up the data while you still can, it is not a good idea to store important files to just one device.
Welcome to the community!
- utelmeAspirant
Hi, Thanks for the fast reply. I did what your recommending and I have already backed up all my files it's 6 bay 12 tera-bytes
in size. When I checked status it shows the current state of all HD within normal temp ranges no noise is heard and Fan one
is displayed under the status I recalibrated it. But the system is not showing system Fan2 at all. The firmware is the last one
released for this model as Netgear is no longer supporting it.
Name: RAIDiator-x86 Version: 4.2.30 Date: Fri Aug 19 16:25:23 2016 Size: 54 MB Here is the status of all the drives:
Disk 1 WDC WD2002FAEX-007BA0 1863 GB , 35 C / 95 F , Write-cache ON OK
Disk 2 WDC WD20EFRX-68EUZN0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 3 WDC WD20EADS-00S2B0 1863 GB , 36 C / 96 F , Write-cache ON OK
Disk 4 WDC WD20EADS-00S2B0 1863 GB , 39 C / 102 F , Write-cache ON OK
Disk 5 WDC WD2001FASS-00U0B0 1863 GB , 43 C / 109 F , Write-cache ON OK
Disk 6 WDC WD2001FASS-00U0B0 1863 GB , 42 C / 107 F , Write-cache ON OK
Fan SYS1 898 RPM OK
Temp CPU 50 C / 122 F [Normal 0-65 C / 32-149 F] OK
Temp SYS 29 C / 84 F [Normal 0-60 C / 32-140 F] OK
UPS 1 CPS CP1500PFCLCD, Battery charge: 12%, 69 minutes OK Here is the log reference to the failure of the Fan2 the system is set up to email me for disk failures/temp exceeding normal ranges.
Fri Mar 3 17:43:47 MST 2017 Fan will be recalibrated over the next few minutes.
Thu Mar 2 16:24:31 MST 2017 System is up.
Thu Mar 2 13:48:25 MST 2017 Fan 2 has failed (SYS1 393 rpm).
Thu Mar 2 13:48:07 MST 2017 System is up.
Thu Mar 2 08:32:13 MST 2017 Fan 2 has failed (SYS1 423 rpm).
Mon Feb 27 23:42:28 MST 2017 System is up.
Sat Feb 25 18:04:58 MST 2017 System is up.
Sat Feb 25 00:07:42 MST 2017 The on-line filesystem consistency check completed without errors for Volume C.
Sat Feb 25 00:00:03 MST 2017 The on-line filesystem consistency check has started for Volume C.
Sun Feb 19 08:10:50 MST 2017 RAID scrubbing finished on volume C.
Sun Feb 19 00:00:16 MST 2017 RAID scrubbing started on volume C.
Sat Feb 18 14:54:22 MST 2017 System is up.
Sat Feb 18 14:48:07 MST 2017 System is up.
Sat Feb 18 11:24:24 MST 2017 System is up.
Sat Feb 18 00:07:25 MST 2017 The on-line filesystem consistency check completed without errors for Volume C.
Sat Feb 18 00:00:03 MST 2017 The on-line filesystem consistency check has started for Volume C.
Fri Feb 17 18:23:59 MST 2017 System is up.
Fri Feb 17 17:06:26 MST 2017 System is up.
Fri Feb 17 00:57:14 MST 2017 The default backup button job copies the contents of the [backup] share to the USB hard drive directly attached to the front of the NAS. Please attach a USB hard drive directly to the front USB port before pressing the backup button.
I suspect the Fan is just broken and needs to be replaced however I need to know the type of fan and where I can get it. I have another Netgear NAS a 4 bay one used for backup of data. The Ultra 6 is a working drive getting used ever day.
Thanks again for replying
Utelme
Hello utelme,
Does this not have warranty anymore? Maybe you can check with support team.
