Qkarmark
Apr 27, 2020Aspirant
Faulty Chassis?
I have a NAS 314 that my co-worker let me keep, it was no longer being used, so I decided to set it up at home as a media server.
I initially installed two existing Seagate drives (250 GB each) that I removed from a desktop computer, and everything was working fine - they were installed into bays #3 and #4.
So I then purchased two more Seagate Ironwolf 4TB drives to put into the remaining two bays. I didn't know that I could access the logs until several days later of waiting for them to finish syncing, but it seems that the drive in Bay #2 was giving me problems - the LED light over bay #2 was flashing so I discovered I could see the logs from my admin page - it was giving me an ATA 20393 error, I did not know what the error meant but it lead me to believe its either the drive or the NAS controller unable to communicate with the drive.
I chose to replace the suspect drive in Bay #2 with a brand new one, and the same thing happened in the same bay.
So now I have removed the two 250 Gb drives, replaced both of them with the new 4TB Ironwolf drives into bays #3 and #4, and everything is fine now. Bay #1 and #2 are still empty.
My question is, can I repair or replace the chassis for Bay #2? If so, where do I find such a part?
thanks
Quentin
FIrst, I would power down the NAS and move the drives into slots 1 and 2. Then power up, and see if the NAS boots properly.
If it does boot, you can go to the volume page in the web ui, click on the volume settings wheel and run a disk test.
If it is the bay, then it's not easily repairable. Netgear doesn't sell parts, and there is no service manual.
- SandsharkSensei
An ATA error, though recorded in the drive SMART data, can be caused by a problem with the interfacing hardware, not the drive itself. Failure to fully seat is often the issue, so look inside and see if there is anything restricting the drive or the connector is broken or dirty. If you see nothing, then the fact that it occurred with two new drives that work in another slot suggestes it is a chassis issue -- probably the SATA backplane. Spare parts are not available, even for original purchasers. So, be happy you have a free 3-bay NAS.
