PropTop99's avatar
PropTop99
Firmware update still says 'Upgrading'; Moving to FW 6.6.1
I started the Firmware upgrade on the ReadyNAS about an hour ago and RAIDar now shows the unit with a different IP, inaccessible and 'Upgrading'.
How long should the process take and what steps SHOULD I be taking right now other than wait? I received the initial email that the system was 'rebooting' but nothing after that point.
Thanks.
R.
  • I waited for 2Hrs and then had the unit power cycled (it's at a remote location). I ran RAIDar again and I'm still getting the same 'upgrading' message. Any suggestions on what to do or what may be going on??
      • PropTop99's avatar
        PropTop99
        I'm not entirely sure. When the Firmware 'Upgrade' popped up on the screen when I logged on, I Ok'd it as it was a good time to get done and didn't think to note the version. Currently, RAIDar shows Status: Upgrading and Firmware under that shows as: 6.6.1
ProSupport for Business
