Simon__'s avatar
Simon__
HDD recommendations for Readynas NV+ v1
I currently have two 1TB Seagate drives (ST31000322CS) which have been in use for 5 years (spin down when not active) and I think are in good health (see below), but I'm running low on space - 192GB free out of 920GB.
I would have been happy to add a couple more of the same drive, but they are not available new any more. The top few drives on the official hardware compatibility list don't appear to be available any more either.
Is it OK to mix capacities (is there any advantage to be had from adding a couple of 2TB drives), or should I stick with 1TB drives?
Any recommendations for HDDs which I can actually buy?
SMART Attribute disk1 disk2
Spin Up Time 0 0
Start Stop Count 65535 65535
Reallocated Sector Count 0 0
Power On Hours 32892 32875
Spin Retry Count 0 0
Power Cycle Count 58 57
End-to-End Error 0 0
Reported Uncorrect 0 0
Command Timeout 0 0
High Fly Writes 55 121
Airflow Temperature Cel 28 30
Temperature Celsius 28 30
Current Pending Sector 0 0
Offline Uncorrectable 0 0
UDMA CRC Error Count 0 0
ATA Error Count 0 0
Hot-add events 0 0
Hot-remove events 0 0
Lp stat events 124 1
Power glitches 0 0
Hard disk resets 0 0
Retries 0 0
Repaired sectors 0 0
  • OK, so if I look up the 2TB drives from Seagate and WD from the HCL with the manufacturers, all but one of those drives is already MD'ed. And the one drive that is not yet MD'ed only has a 1 year warranty.
    So,if I want to abide by the HCL and max out my NV+ capacity, I have little or no choice in hard drives, and must accept buying product with a 1 year warranty for a high reliability application (hmmm...).
    Let me ask then, whether there is any further testing of (newer) 2TB drives planned for the NV+ ?
    Have you heard (or expecting) anything back from the QA team on this topic ?
    Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I agree that we need to get some newer 2TB disks on the list.
    I have been discussing this with the QA team.
    Hi,
    Any news on that ?
    One of my HDDs caused my NV+ to hang up, seems the HDD's fried according to the vendor diagnostic tool :
    Funny thing is that I had absolutely no warning ahead of time, despite email alerts being set.
    Anyway, I have to replace it ASAP. I'm considering the WD "Red" series. But if the 1TB one is listed in the HCL (WD10EFRX), the 2TB one isn't (WD20EFRX). It seems those are running well on Duo according to some messages I found on this forum, but should I expect any trouble with my NV+ or can I go ahead without worries ?
    I know critical data are to be on backup, but it would be no fun to restore, especially when trying to get back all the non-critical stuff I can't afford to backup easily.
  • StephenB's avatar
    I've had no issues with the 2 TB Red in the duo v1.
    Though I'd suggest you invest a bit in more backup capability. USB drives are not expensive.
    mdgm-ntgr
    Disks can and do fail at any time. Sometimes without any warning (which is one reason why backups are important).
    I would certainly prefer WD RED drives over Green drives.
    I will need to follow up on where things are at.
    Thanks for the confirmation.
    6TB USB drivers tends to be on the expensive side ;) I CAN backup critical data (which is way less than that), it's all the "confort" stuff on the side which would be a pain ;)
  • StephenB's avatar
    You can use multiple disks of course - you just need to manage the maximum share size to fit a reasonable capacity.
ProSupport for Business
