cbcaqui
Dec 13, 2017Follower
How do I connect to the readyNAS to view or change it's configuration
I have an old ReadyNAS which I need to point some backups too. I beleive it was previoulsy configured but it's been unplugged and off the network for a while. I see there is nowhere to connect a cons...
Dec 13, 2017Guru - Experienced User
RAIDar is the right tool. You might try the 4.3.8 version instead of the newer OS 6 version. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
If you are prepared to rebuild it, perhaps just do a factory reset and then look for it with RAIDar.
This is a Readynas 2100?
