SWhetsel's avatar
SWhetsel
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below)
    1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the share.
    2. Enable Root SSH on the ReadyNAS.
    3. Install PHP on the ReadyNAS.
    4. Install the PHP5-MySQL package.
    5. Download and install Joomla 1.5 on the ReadyNAS.
    6. Setup your Joomla 1.5 MySQL database.
    7. Follow Joomla 1.5 installation Instructions.
First off, I am sorry to those that are fluent in SSH, but I was not when I wanted to do this and therefore took me forever to figure out. (ok not exactly forever, thanks Google) So I am writing this guide very simple and with literally every step. I am going to break it down , Barney style. Also needed is an SSH client if you’re doing this all via windows like I was. I suggest PuTTY as it is free. You can get PuTTY Here. (http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html) I also wanted to thank the people that wrote the other helps out there, especially the ones that are linked in this walk through. So without further wait, here is how you install Joomla on ReadyNAS boxes. (FYI this was done on a ReadyNAS Duo)
Step 1 – Create a website share that’s accessible outside your firewall
Follow the instructions in the Create a personal webserver on the ReadyNAS how-to.
(http://www.readynas.com/?p=135)
Step 2 – Enable Root SSH
Install the EnableRootSSH add-on. Installation instruction is available from the ReadyNAS Add-ons page.
(http://www.readynas.com/download/addons/4.00/EnableRootSSH_1.0.bin)
Step 3 – PHP
Follow the instructions in the Setting up a PHP CGI Environment how-to.
(http://www.readynas.com/?p=140)
Or just follow these quick steps.
SSH into your ReadyNAS via PuTTY.
Login Username is “Root” and Password is your admin password for the ReadyNAS.
Copy these following commands into PuTTY.
# apt-get update
# apt-get install libapache2-mod-php5
After they are done installing then run these commands.
# killall apache-ssl
# apache-ssl -f /etc/frontview/apache/httpd.conf
Step 4 – Install PHP5-MySQL package
From the root shell, run the following:
# apt-get install php5-mysql
Step 5 – Download and extract Joomla 1.5
Directions to download and extract Joomla 1.5 are as follows: (I tried this with 1.6 to no avail so this is what worked for me with 1.5) Download zip file Joomla 1.5 and extract all files into the folder you created in step 1. The actual install happens later.
Step 6 – Setup your MySQL database
Before creating your MySQL database file, you’ll need to first modify the file /etc/mysql/my.cnf.
You can use the built-in vi text editor to do this. (vi commands are in the link at the bottom)
Search for the following line in /etc/mysql/my.cnf:
skip-networking
and insert a ‘#’ sign in front of it to comment out the line. The resulting line should look as follows:
#skip-networking
Once you’ve saved the change, you’ll need to restart MySQL as follows:
# mysqladmin shutdown
# mysqld
Now, let’s create the MySQL database for Joomla. When prompted for password, just press “Enter”. We”ll use “page” as the database name and “admin” as the user name. You can set up the password in the IDENTIFIED BY “password” line to whatever you want.
# mysql -u root -p
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 5340 to server version: 3.23.54
Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> CREATE DATABASE page;							(press enter)
Query OK, 1 row affected (0.00 sec)
mysql> GRANT ALL PRIVILEGES ON page.* TO "admin"@"localhost"   	(press enter)
-> IDENTIFIED BY "password"; (press enter)
Query OK, 0 rows affected (0.00 sec)
mysql> FLUSH PRIVILEGES;							(press enter)
Query OK, 0 rows affected (0.01 sec)
mysql> EXIT										(press enter)
Bye
Step 7 – Install Joomla!
Follow the directions at the following site: Joomla Install via Website
(http://help.joomla.org/content/view/39/132/)
VI Commands Cheat Sheet - http://www.lagmonster.org/docs/vi.html
Enjoy! -SWhetsel
  • nas-xx-xx-xx:/etc/init.d# apt-get install mysql-server
    Reading Package Lists... Done
    Building Dependency Tree... Done
    The following extra packages will be installed:
    libdbd-mysql-perl libdbi-perl libmysqlclient12 libnet-daemon-perl libplrpc-perl mysql-client
    Suggested packages:
    dbishell libcompress-zlib-perl mysql-doc
    The following packages will be REMOVED:
    mysql-client-5.0 mysql-server-5.0 squeezecenter-readynas
    The following NEW packages will be installed:
    libdbd-mysql-perl libdbi-perl libmysqlclient12 libnet-daemon-perl libplrpc-perl mysql-client mysql-server
    0 upgraded, 7 newly installed, 3 to remove and 71 not upgraded.
    Need to get 5377kB of archives.
    After unpacking 40.7MB disk space will be freed.
    Do you want to continue? [Y/n]
    All right - so this will remove sqeezecenter server from my box? I don't use it now, but I may need this one day.
    Should I say Y or n??? :-)
  • Okay Gentleman, somehow I managed to get to this point:
    nas-xx-xx-xx:~# mysql -u root -p
    Enter password:
    Your MySQL connection id is 1 to server version: 5.0.24a-Debian_3.infrant1
    Query OK, 1 row affected (0.04 sec)
    mysql>
    mysql> EXIT
    Bye
    nas-xx-xx-xx:~#
    The trick was to do this
    nas-xx-xx-xx:/# mysqld
    120608 23:31:34 InnoDB: Started; log sequence number 0 43655
    120608 23:31:34 [Note] mysqld: ready for connections.
    Version: '5.0.24a-Debian_3.infrant1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 Infrant ReadyNAS distribution
    on one terminal, and then login with new ssh session and do
    mysql -u root -p
    I hope now I can go to installing actual joomla :-)
    I think 1.7 should be fine for me, or can I try with 2.5?
  • So joomla 1.5 seems to work on my Duo now :-)
    The database "page" created this way as above is located on the system partition of the ReadyNAS, isn't it? Where the actual data of this database will be stored? I would prefer to store data on website share rather then on the system partition.
  • I believe the default datastore is /var/lib/mysql, but you can change this as you please. Just do as follows:
    sudo /etc/init.d/mysql stop
    sudo vi /etc/mysql/my.cnf
    Comment out this line with a hashtag
    datadir         = /var/lib/mysql
    and copypaste another one underneath where you change the dir to wherever you want to place it.
    Then:
    cp /var/lib/mysq /where/you/wat/the/data
    sudo chown -R mysql:mysql /where/you/want/the/data/*
    however, you should delete ib_arch_log_0000000000, ib_logfile0 etc. from the new directory.
    After that you'll be able to just go ahead and restart the sql service with
    sudo /etc/init.d/mysql start
  • Linux nas-xx-xx-xx 2.6.17.14ReadyNAS #1 Thu Sep 1 17:44:33 PDT 2011 padre unknown
    nas-xx-xx-xx:~# sudo /etc/init.d/mysql stop
    sudo: /etc/init.d/mysql: command not found
    nas-xx-xx-xx:~#
    I don't know why. Mysql seems to work on my NAS, as well as joomla works and the installator of joomla detected mysql and was able to connect to the database.
  • I'll attach a link to a generic init.d file for mysql in the bottom of this reply.
    However, I strongly recommend starting over and strictly following my guide to
    make sure you're not missing anything else vital.
    http://dl.dropbox.com/u/9085001/mysql
  • Hey there.
    I am also trying to install Joomla on my Readynas Duo. I've managed to make it to step 3. I've installed the enable root SSH and I am able to access the NAS with Putty, using root and my password. However after inputtig the commands listed nothing happens. I don't get an 'unkown' command message but neither do I get any verification that something is being installed or downloaded.
    Did I skip something or am I doing something wrong?
  • Hi Broadside, I think you didn't install the APT on your ReadyNAS.
    This link contains the same instructions as Step 3 with added link to the APT add-on.
    http://kb.netgear.com/app/answers/detail/a_id/12272/~/setting-up-a-php-cgi-environment
    Not to revive such of an old thread, I have a slight different problem than Broadside. I'm actually stuck in Step 3.
    When I ran:
    # apt-get update
    I get:
    You might want to run `apt-get -f install' to correct these:
    The following packages have unmet dependencies:
    libapache2-mod-php5: Depends: libbz2-1.0 but it is not going to be installed
    Depends: php5-common (= 5.2.0-8+etch9~bpo31+1.netgear1) but it is not going to be installed
    Depends: ucf but it is not going to be installed
    php5: Depends: php5-common (>= 5.2.0-8+etch9~bpo31+1) but it is not going to be installed
    php5-mcrypt: Depends: php5-common (= 5.2.0-8+etch9~bpo31+1.netgear1) but it is not going to be installed
    E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
    Should I be trying to install all the listed dependency packages? Or just run
    apt-get -f install
    ? Or am I doing something wrong?
    Sorry for the newbie questions. A bit of a Linux noob.
ProSupport for Business
