Trench_Rich
Aug 08, 2018Aspirant
how to vertically expand a ReadyNAS 104
I bought a ReadyNAS104 a couple of years ago with one 3TB disk.
Now that that disk is full, I bought another 3TB disk to increase the capacity to 6TB.
I stuck the new hard drive into the box, and waited overnight for the system to adjust itself.
I came back the next day to find that even though I now had two volumes, I still only had 2.72TB of space.
How do I get the system to recognise the increased capacity?
Vertical expansion: expanding capacity by replacing smaller disks with larger ones
Horizontal expansion: expanding capacity by adding drives to empty bays.
So what you attempted was horizontal expansion, not vertical. However, as you discovered, adding a second 3 TB drive doesn't expand capacity. With XRAID, adding the second disk gives you RAID redundancy - protecting your data from a routine disk failure. That can't be undone without destroying your data.
The simplest solution is to purchase another 3 TB drive and put it into slot 3. If you do that, your capacity will increase to 6 TB (~5.45 TiB). Adding a fourth 3 TB drive would give you 9 TB (~8.2 TiB) of total space.
Your other option is to back up your data, do a factory reset on the NAS, set it up again in flexraid mode - creating two volumes (one for each disk). Put some shares on each, and then restore your files from the backup.
Note it is possible to create a single 6 TB volume that spans both disks. However, that is a risky thing to do. When either drive fails you will lose all the data on the NAS. With two volumes, you'd only lose the data on the failed drive.
- Marc_VNETGEAR Employee Retired
Hi Trench_Rich
Welcome to the Community!
This is normal, this is due to the configuration your NAS might be into, If you can check under the volume tab on your ReadyNAS Admin page, XRAID is used which will represent enabled with a blue color line.
What happened is that your 1 3TB disk which is in JBOD has changed to a mirror RAID (RAID 1) after you have added the 3TB disk on your NAS making it an exact copy/mirror of your current disk.
IMO, you can add another drive or two to make it RAID 5 making it expand it's capacity or You will have to start over by turning of XRAID and destroying the current RAID then setting it up with 2 3TB on JBODs or do a factory reset
You need to make a backup first since Destroying the volume will remove all your data as well.
Hope this helps!
Regards - Trench_RichAspirant
If I remove the second drive and reboot the NAS, is there any way to get it back to a single disk system and start over?
Could I then make the system into a JBOD (or something) array and have it (re)format the second hard drive so I can use it?
There is no other way than to change to Flex-RAID and destroy the current volume created or do a Factory reset and start with Flex-RAID. The RAID is now RAID 1 so these are the only option :(
Both will be destructive so you need to do a backup.
Regards
- JBDragon1Virtuoso
What sounds like happened is that the NAS which had no backup, and really basically running like any old single drive HDD you can plug into your computer took that second HDD and did a direct copy of the first HDD, now using RAID 1. What you do to one HDD is done to the second HDD as a copy. If either HDD takes a dump, you can swap it out with a new HDD and all your data will be copied to that new HDD from the 1 working HDD.
What YOU seem to really want to use is called RAID 0. This is in fact what I use on my second NAS which I use for a Backup. It's backing up my 6 HDD NAS which has 6, 3TB HDD in it and copying all that Data onto 2 8TB HDD in RAID 0 giving me enough space. Since this is a backup NAS, and it only runs 2 days a week and only late at night. It automatically powers up, and ready when my Main NAS starts copying anything NEW over to it. In the morning that NAS powers down once again for a few days. So it's not on much and I have a backup. I have a copy of my files on one or the other NAS unit.
The big NAS is using RAID 5. So basically I have Data on 5 of my 6 HDD's in such a way if any of the 6 HDD fail, I can swap it out with a new HDD and the NAS will rebuild its self, losing no Data. Now RAID 0 will give you want you want. 1 BIG HDD using 2 drives. So double the storage space. But you also have double the odds of a HDD failing and losing ALL of your data from both HDD's!!! You were already taking that risk, so continuing to do that is on you. The problem is now, I don't think you can change it from Raid 1 to Raid 0 without removing the Data on it and starting over. I'm not 100% sure. So you may have to copy the Data on it off to someplace else, then reformat to raid 0, and then put your files back onto it.
So this explains RAID.
https://en.wikipedia.org/wiki/RAID
So you are using RAID 1 currently as that is what the NAS would normally do on its own when just popping in a second disk. You want RAID 0. So go to that link and it'll explain RAID 0 and RAID 1.
Also because you're going to use RAID 0, you won't be able to Vertically expand once both drive bays are full for sure. Because pulling one drive means losing all your Data. It would be impossible to pop in a replacement larger HDD and rebuilt since the data you would need to rebuild with is on the drive you pulled. Without those 2 drives together, you can't rebuild. On the other hand, using RAID 1, since they are clone drives. You could pull either of the 3TB drives, pop in a 6TB drive and it would copy everything from the 3TB drive to it. But still look as a 3TB HDD until you replaced the second 3TB HDD with another 6TB HDD and the data cot copied over. Then it would look like a 6TB NAS using RAID 1. Later expand to maybe a 10TB HDD. See you can't fill 1, 6TB HDD with 5TB of Data and expect the 3TB drive to hold 5TB of Data, so it can't be RAID 1 and see the 6TB drive without both being 6TB's. Doesn't matter the size, they both have to be equal to use all the space. On the other hand RAID 0 doesn't matter. It'll throw a 3TB and a 6TB together making 1 large HDD and using all the space. BUT you have ZERO redundancy. Double the odds of a HDD failure losing ALL of the data on both HDD's. A NAS already is not a BACKUP. A backup is having you Data in at least 2 different places. Offsite as a 3rd backup is even better.
You're not really even using the benefits of a NAS. You could have just got a cheapo 3TB External drive and plugged the thing into your computer. If you need more space, buy another external HDD and plug that in also. I'm just trying to warn you of the risks. HDD's do fail. Sometimes quickly to maybe lasting YEARS. You having 2 HDD ina RAID 0 means double the risk of losing everything. Maybe quickly, to maybe years down the road. I have WD RED drives in my NAS that are over 5 years old and zero errors and problem free. Others haven't been so lucky. So Cheapo External drives plugged into your PC. It's not in RAID. If one of them dies, it doesn't affect any others. On the other hand, I don't know what you're doing with your NAS.
Perhaps it's best to not reply with "what I AM doing with my NAS" as what I want (and what I thought a NAS would do).
I have a 1 TB laptop, my wife has a 500 GB laptop, and we both have several external hard drives of varying sizes.
What I want is for a large network hard drive that can back up all these things conveniently, not having to plug things in and out of our laptops all the time.
I thought a NAS would do that, leaving me room for expansion as my finances would allow.
It appears I was wrong.
What solution is possible?
We already told you that. You have two options
- add a third drive, which would double your current capacity and preserve your RAID protection or
- Offload your data, do a factory reset, and set up the NAS as jbod. Then restore the data.
Either way you will need to spend money - either on a third internal drive or a backup USB disk. If you had asked here before you inserted the disk, we would have told you how to avoid that expense. But now that you have a RAID-1 volume, that isn't possible.
Note that if you care about data safety, you do need to back up your data to a different device. You aren't doing that, and therefore your data is always at risk of being lost. If I had to choose between the two options above, I'd go with (2) and invest in a backup USB disk that is large enough to store all my data. Backup is more valuable to me than RAID protection.
