GRRRRRR
Dec 25, 2019Aspirant
I am stuck at everything looks like it work but...cannto log into ReadyNAS nv+
I bought this NAS from a friend before he returned to China. It worked on his machine. I set it up and installed 4- 4T drives as directed by the hardware manual.THe machine initialized and formatted ...
- Dec 25, 2019
Do you know the admin password for the NAS?
Also, is the PC running Windows 10? if not, what is it running?
Try installing RAIDar on a PC, and see if it can discover the NAS. If it does find it, can you let us know what firmware it is running (either 4.1.x or 5.3.x). Also note the IP address. https://kb.netgear.com/20684/ReadyNAS-Downloads
Dec 25, 2019Guru - Experienced User
GRRRRRR
Thank you. I managed to install that software and i logged into the NAS. Now I am working through all the setup steps. I appreciate your help. Karena
