gdaymate1
Apr 10, 2012Aspirant
Is SATA 3Gb/s interface the same as SATA 6Gb/s?
This is probably a stupid question... I have a ReadyNAS Ultra 2 and I tried to put in a Seagate Barracuda 1Tb 7200.12 disk, but it didn't seem to fit! I noticed on the HCL that this model is the 3G...
PapaBear1
Apr 10, 2012Apprentice
There is only one SATA interface and it is the same over all hard drives, be they SATA 1.5Gb/s, 3.0Gb/s or 6.0Gb/s or even if it is a 3.5" or 2.5" drive.
As to the ST31000528AS, I have 10 of them, and have had all of them in service at one time or another in the last three months between two NVX units and one NV+ unit. I currently have 4 in service across two NVX units and have given away two of them installed in my NV+ when it was rehomed.
Are you using the small flat head screws that came with the Ultra 2? Standard HD screw will not work! Chapter 4 of the hardware manual has a diagram.
