claykin
Sep 25, 2012Aspirant
large USB disk for Sparc and x86 - 4K or 512e?
I need to get two large USB disks for an NV+ and an NVX. Yes, I know the NV+ USB disk cannot exceed 2TB, however it seems many of the modern off the shelf USB disks are using drives with 4Kb sectors....
maxblack
Sep 28, 2012Aspirant
mdgm wrote: You can easily check if the drive is 4k sector partition aligned via SSH if you are comfortable with using that.
But in the post below, you say you just have to look at the log? What's the diff vs. "via SSH"?
viewtopic.php?f=17&t=46183#p263353
