claykin
Sep 25, 2012Aspirant
large USB disk for Sparc and x86 - 4K or 512e?
I need to get two large USB disks for an NV+ and an NVX. Yes, I know the NV+ USB disk cannot exceed 2TB, however it seems many of the modern off the shelf USB disks are using drives with 4Kb sectors....
mdgm-ntgr
Jun 19, 2013NETGEAR Employee Retired
What version of RAIDiator?
Have to tried both front and rear ports?
Also, I see this is a portable hard drive. It's possible the USB ports in the NAS aren't supplying enough power to the drive. Have you tried plugging the USB drive in via a USB Hub which has its own power supply?
Also one post is enough. You don't need to post the same thing in three threads.
