claykin
Sep 25, 2012Aspirant
large USB disk for Sparc and x86 - 4K or 512e?
I need to get two large USB disks for an NV+ and an NVX. Yes, I know the NV+ USB disk cannot exceed 2TB, however it seems many of the modern off the shelf USB disks are using drives with 4Kb sectors....
pillick
Jun 21, 2013Aspirant
I just need one answer, in any of the threads would be fine.
Radiator 4.10, the most recent for the v1 Duo. Yes, tried both front and rear USB ports. Yes, I've tried different cables, powered USB hub and unpowered cables, one USB connection each end and even one of the two ended USB cables, designed precisely so older drives get enough power, with the two-ended side plugged into the Duo. Other external drives work (2.5" laptop USB), this one, seemingly the most common generic Seagate drive, doesn't.
