janpeter1's avatar
janpeter1
Luminary
Jun 27, 2015
Likely Readynas 3-series
Hello,
I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1.
Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small office.
I have questions concerning the advantage of separating data on different disks
or more software division in volumes and share provide enough separation.
Typically I need on the NAS for the coming years
A : Archive data - photos, media etc - accumulate over time does not change - about 1.5 GB growing
B : Backup of 3-4 Macs - need about 1 TB for that - change as backups do
C: Shared folders in the LAN - need about 0.1 TB for that - change a lot
D: Shared folders externally over internet with business clients - need about 0.2 TB for that - change a lot
- need encryption and security
E: Web-page - 0.01 TB or so - need internet security etc
Today I only have A-C but consider to expand the use with D and E with the new NAS
The old Duo likely will be the new backup destination.
Questions (after reading briefly in Readynas Software Manual 6.2):
1) Enabling bit-rot protection is mainly interesting for A and perhaps B
Should this be on typically 2 raid1 diska and physically separated from another 1-2 disks (for C-E)?
Hear that it should perhaps not be enabled where data is changed all the time
since that would lead to disk fragmentation, but I may misunderstand this.
2) Enabling encryption for a part D (for business sharing over internet) is that possible? and if so
recommended to have that for a separate disk? or enough with a separate volume on a disk
that is otherwise not encrypted?
3) Security against un-friendly internet access. Consider to house a web-page or two on the NAS
but worried for that it opens up for attacks from outside. Does it help in anyway to
have such stuff on a separate disk? or enough with separate volume?
4) I know the volume can be divided up in shares and each share can be password protected
and so I actually work today. Is there any advantage of dividing more physical into separate disks
or share separation is enough? So would a 2-bay system with shares for A-E give about
the same integrity, security, performance?
5) I read in the manual that enabling checksum and bit-rot protection decrease performance.
If i have I have 2 disks raid1 configured and divide into two volume one with checksum and bit-protection
enabled and the other without, will they then have different performance? Or do I need to
have the volume without checksum and bit-rot-protection on a separate disk to get the performance gain?
b) Same question for disk fragmentation?
6) Last question Is the limitation to 4TB disks on 3-series a hardware or software-constraint, i.e.
can a future upgrade of OS 6 open up for larger disks?
Generally speaking I do not think performance is an issue. My focus is mainly on data-integrity and
internet security if I open up for internet access option D and E above.
The questions span a large range and would appreciate also partial response.
Thanks
  • You could put a suggestion in the Feature Request & Feedback subforum.
    You could also make a request at rnxtras.com (not a netgear site)
ProSupport for Business
