Johncaputo
Sep 04, 2019Tutor
Loading please wait loop
When i attempt to log onto our cloud it just says loading please wait and it keeps refreshing and trying on its on in a loop. I reset our cloud and network and this didn't solve the problem. The lack...
Zizuar
Dec 21, 2019Aspirant
Both were no goes. A later attempt to access the admin page directly got me to the login but not past it. Kept telling me the network got reset.
Dec 21, 2019Guru - Experienced User
Did you get the login prompt?
Were you using the NAS name in the URL or the NAS IP address?
Zizuar wrote:
Both were no goes.
If ping fails, then you should look into that first. After the factory reset, the NAS will use DHCP. Have you confirmed the NAS has a valid IP address for your network?
- TimHKJan 03, 2020Aspirant
What is the solution to get through??
