icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello,
I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0
Thanks
:D
Thanks
:D
- nsneVirtuosoUE media server is no longer installing for me. I'm running 6.2.4 — it stopped working somewhere around the 6.2 iterations. I've tried all the suggested steps (installing LMS, then uninstalling; installing LMS, then installing UE; etc.) and nothing works.
Would someone be so kind as to make a ReadyNAS app out of the latest version of the UE Music Library (available here) so those of us running a UE device can access our music?- icyvranTutor
Hi,
I got it working again on ReadyNAS OS 6.2.4. This is what I did:
Using the manual installation of the deb files. You can read a tutorial here: https://rnxtras.com/add-on-installation/add-onapp-installation-on-readynas-os-6-arm-x86
First I installed the lms_1.0.8_all.deb from:
It will fail, but it doesn't matter.
Then I installed UE Music Library Debian Installer Package from: http://downloads.slimdevices.com/nightly/?ver=10.0
- smallsingsAspirantOkay before i tell what it did: at my Readynas it WORKED!
Thanks markwoll!
I have Firmware 6.1.9
I installed the Logitech Media Server in the app section.
After installing I deinstalled it and manually installed "UE Music Library: Debian Installer Package".
It takes a while and first it said that installation failed....but a second try my Readynas said it was successfully installed.
So just wait a bit like markwoll said.
The App is not shwon in the installed apps section.
But with putting the portnumber ":3546/" behind the IP of your Readynas you have the server!
Perfect!
Here a screenshot of the Log:
- markwollGuide
smallsings wrote: Hello,
so i tried to install the "UE Music Library: Debian Installer Package" on my Readynas 314, but the installation process was not working.
is there a solution without having the ssh root stuff?
Did you install the lms_1.0.6_all.deb file?
I think that is a prereq for installing one of the deb files from the logitech repository.
May be wrong, but don't think it would hurt before trying the UE Music Library installer again.
Even though I use the LMS package, the above file seemed to take a while before it installed, on a 516. - nsneVirtuosoThat's a bummer. I was growing impatient and was thinking about just giving it a whirl myself.
How exactly does one install the Debian installer package via SSH? - smallsingsAspirantHello,
is there a solution without having the ssh root stuff? - smallsingsAspirantHey nsne!
not yet...I bought the 314 just a few days ago and still waiting to have it in my hands ;)
But I'm happy not to be alone with that topic ;)
The only thing (without) trying it by ourselves is to ask Superpoussin...but till now i waited if somebody has experience and is writing his/her answer here! - nsneVirtuosoLike the OP, I'm also looking for info on the UE Music Server on ReadyNAS OS 6. Keep in mind that UE Music Library is like LMS but it's not the same. UEML is designed to work with Logitech's new UE Music devices.
Up to now with my ReadyNAS Ultra 4, I was running the UEML and updating it manually using the "Pro" installer from the nightly build page linked above: http://downloads.slimdevices.com/nightl ... p?ver=10.0
Now I've got a 314 running ReadyNAS OS 6, but I'm not sure if I can simply use the Debian installer from that page.
@smallsings, have you had any luck running that installer? My bedroom radio is going to be without access to my music collection if I can't run the UE Music Library on my ReadyNAS. - smallsingsAspirantThanks markwoll!
But the Thread you mentioned is for the Logitech Music Server, which is just able to operate with the Squeezebox.
In my case, i wanna know more about the UE Smart Library Addon, which is for the new Squeezebox, the UE Smart Radio. - markwollGuideFor the OS6 Readynas devices see this thread:
viewtopic.php?f=153&t=73375&hilit=squeeze - smallsingsAspirantI am also really interested in installing the UE Smart library on my Readynas 314.
I was thinking about installing the "UE Music Library: Debian Installer Package" directly, but did not try it till now...
@mrfusion did it work?
Thanks for your help!
