KJ
Feb 05, 2007Aspirant
MRTG config info
Since I have been struggling to figure this out, I thought I would share my mrtg.cfg file set up to monitor eth0 on our ReadyNAS NV+:
I couple of FYIs here:
The MIB might not even be necessary for the network statistics, but you can download it from the Infrant website here:
http://www.infrant.com/download/INFRANT-MIB.txt
This was on a NetBSD box, so your path to the username directory may look different (or wherever you decide to put it). You'll have to fill in the correct path/username. The IP address will be different as well.
That all being posted... does anyone know how to set up a config to show the volume statistics? (used, free, total)
Thanks!
KJ
### Global Config Options
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
LoadMIBs: /home/username/www/mrtg/INFRANT.MIB
WorkDir: /home/username/www/mrtg
Options[_]: bits, growright
# System: ReadyNAS
# Description: Linux ReadyNAS 2.4.20-3.00c1.0 Wed Nov 29 15:20:42 PST 2006 sparc
# Contact: root
# Location: Unknown
Target[nas]: 3:public@192.168.1.17:
SetEnv[nas]: MRTG_INT_IP="" MRTG_INT_DESCR="public"
MaxBytes1[nas]: 1000000000
MaxBytes2[nas]: 1000000000
Title[nas]: Traffic Analysis for ReadyNAS
PageTop[nas]: <H1>Traffic Analysis for ReadyNAS at 192.168.1.17</H1>
Thanks!
KJ
- saxofonAspirantProbably too late and you've already done this, but anyway... here's my attempt. :)
Pitty the drive temperatures not seem to be in mib :(
But at least I also get temp, fan and free space now. :)
SingleRequest: Yes
Directory[_]: raid1
Target[raid1_eth]: 3:public@raid1
MaxBytes[raid1_eth]: 1250000000
Title[raid1_eth]: raid1 eth
PageTop[raid1_eth]: <H1>raid1 eth</H1>
Target[raid1_fan]: .1.3.6.1.4.1.11500.1.4.1.2.0&.1.3.6.1.4.1.11500.1.4.1.2.0:public@raid1
Options[raid1_fan]: growright, gauge, nopercent, noo
MaxBytes[raid1_fan]: 5000
Title[raid1_fan]: raid1 fan
PageTop[raid1_fan]: <H1>raid1 fan</H1>
YLegend[raid1_fan]: RPMS
ShortLegend[raid1_fan]: RPMS
LegendI[raid1_fan]: Rear fan
WithPeak[raid1_fan]: ymwd
Target[raid1_temp]: .1.3.6.1.4.1.11500.1.5.1.2.0&.1.3.6.1.4.1.11500.1.5.1.2.0:public@raid1
Options[raid1_temp]: growright, gauge, nopercent, noo
MaxBytes[raid1_temp]: 100
Title[raid1_temp]: raid1 temp
PageTop[raid1_temp]: <H1>raid1 temp</H1>
YLegend[raid1_temp]: Celcius
ShortLegend[raid1_temp]: C
LegendI[raid1_temp]: System
WithPeak[raid1_temp]: ymwd
Target[raid1_vol]: .1.3.6.1.4.1.11500.1.7.1.5.1&.1.3.6.1.4.1.11500.1.7.1.6.1:public@raid1
Options[raid1_vol]: growright, gauge, noi
MaxBytes[raid1_vol]: 1418752
YTicsFactor[raid1_vol]: 0.001
Title[raid1_vol]: raid1 volume
PageTop[raid1_vol]: <H1>raid1 volume</H1>
YLegend[raid1_vol]: GB
ShortLegend[raid1_vol]: GB
LegendI[raid1_vol]: Total
LegendO[raid1_vol]: Free
Unscaled[raid1_vol]: ymwd - KJAspirant
No -- I hadn't yet. Thanks for the info! - GurutekAspirantHi Guys
You'll have to excuse me, I'm an MRTG newbie. OK, first things first, I'm successfully monitoring some PC's on my network using MRTG, and now I want to start monitoring my ReadyNAS. I'm not too sure what the MIB thingy is all about, nor what to do with it? If someone could please explain howto monitor the readynas with MRTG, or even just point me in the right direction.
Thanks for your help gents.
Regards
Robbie - saxofonAspirantHi Gurutek,
Well, you say you can monitor som PC's using MRTG.
Good, then you are almost home!
Cut&paste my mrtg "code" into a file (i call it raid1.inc)
You need to tweak it a little bit to match your setup,
at least the "target" rules needs to be redefined for your host
[root@mms mrtg]# grep Target raid1/raid1.inc
[root@mms mrtg]#
The last "raid1" word in above lines should be the IP (or hostname if your dns things are
ok) that points to your ReadyNAS box.
I don't think you need to use the infrant MIB since the snmp variable is numerically
specified instead of via symbols.
In your top mrtg config file (usually /etc/mrtg/mrtg.cfg) you can
include this file like:
include: raid1.inc
Thereafter, you just issue the commands to generate html/mrtg files as you've done before.
It aint difficult at all :roll: - GurutekAspirantWell, after following Saxofon's instructions, and a little tweaking I was able to get the info I needed on my ReadyNas. Here is what the NAS section of my MRTG.CFG file looks like:
# System: ReadyNAS
# Contact: root
# Location: Unknown
SingleRequest: Yes
Directory[_]: NAS
Target[raid1_eth]: 3:public@192.168.0.2
Title[raid1_eth]: ReadyNAS GigaBit Eth0
PageTop[raid1_eth]: <H1>ReadyNAS Gigait Eth0</H1>
Target[raid1_fan]: .1.3.6.1.4.1.11500.1.4.1.2.0&.1.3.6.1.4.1.11500.1.4.1.2.0:public@192.168.0.2
Title[raid1_fan]: ReadyNAS Fan Speed
PageTop[raid1_fan]: <H1>ReadyNAS Fan Speed</H1>
Target[raid1_temp]: .1.3.6.1.4.1.11500.1.5.1.2.0&.1.3.6.1.4.1.11500.1.5.1.2.0:public@192.168.0.2
MaxBytes[raid1_temp]: 50
Title[raid1_temp]: ReadyNAS Temperature
PageTop[raid1_temp]: <H1>ReadyNAS Temperature</H1>
LegendI[raid1_temp]: Temp
I couldn't get the volume bit to work - but don't really need this. I am also interested in getting the CPU load - Does anyone know how to go about getting the numeric SNMP variable for CPU load? How do you find out any of the SNMP variables?
Does anyone else know of any other interesting things to monitor on the ReadyNAS?
Thanks for the help Saxofon :) - GurutekAspirantPosted Config again - Disabling HTML this time :)
# System: ReadyNAS
# Contact: root
# Location: Unknown
SingleRequest: Yes
Directory[_]: NAS
WithPeak[raid1_temp]: ymwd - PiggelmeeAspirantThe SNMP targets have been changed in the new RAIDiator v4 firmware.
This is the new ReadyNAS MIB: READYNAS-MIB.txt (unable to post the link due to the spamfilter, the link was posted in the Feedback forum)
I succesfully monitored the traffic, fanspeed, temp and diskspace with MTRG as described in this thread, but since I upgraded to v4 this doesn't work anymore.
I already found the new target for the network traffic:
Firmware v3: Target[raid1_eth]: 3:public@192.168.0.2
Firmware v4: Target[raid1_eth]: 2:public@192.168.0.2
How can I determine the MRTG Target OID's for temp, fan and volume from the new MIB? Has anyone figured this out yet? It seems that the individual disktemp can be monitored now as well, but again: how do you figure out the new targets?
Thanks and regards,
Paul - saxofonAspirantsnmpwalk is your friend :idea:
- PiggelmeeAspirant
saxofon wrote: snmpwalk is your friend :idea:
I would appreciate if you could be a little bit more comprehensive. I already played around with snmpwalk and snmpget for a while, but it still doesn't make much sense. If I try this command:
snmpwalk -M readynas.mib -v 1 -c public readynas.mydomain
the output is a huge list of OID's and their values. But how do I tell which OID represents what?
Thanks in advance for your help! - ginneAspirantHow did you guys got MRTG working at all?? I have massive trouble with perl while installing it:
http://www.infrant.com/forum/viewtopic. ... light=mrtg
Hope some one can help me
Regards Guenther
