aaduwaikh
May 21, 2012Aspirant
NAS & Security System Choices
I own an NV+ Ver 1 and have used it to stream video over a local home network, store files and PC backup images. Performance copying large files to and from the NV+ is acceptable but not wow. I am e...
Edwin1
Aug 06, 2013Aspirant
I think the CCTV cameras are best for the security.And you can easily installed and programmed it self.There is also a feature that you can monitor them using the security apps on your mobile and get the live videos from that cameras.
