Maxpower411's avatar
Maxpower411
Netgar ReadyNas 516 New Drive Install Seagate-Command Timeouts
Problem with ReadNas 516 Diskless Firmware on NAS 6.75 All New Drives Seagate ST6000NE0021 3 No Problems with new install in a used NAS except for Disk 3 has 20 command timeouts, Disk 5 has 7 Comm...
  • StephenB's avatar
    Aug 14, 2017
    I haven't seen this myself.  I believe the drive counts ATA errors, but the OS drivers might be counting the command timeouts.  If so, I think that an issue with one drive can cause sata bus timeouts on other drives.
    Can you look in disk_info.log, and see if there are ATA errors there (and if they are tracking the command timeouts)?
ProSupport for Business
