jholden's avatar
jholden
Network connection drops after a few hours.
My ReadyNAS Pro6 drops network connection every so often, it started happening after the last firmware update to RAIDiator 4.2.30. It works fine after I reboot it, then it drop all netwrok connectivity after a few hours untill it's manually restarted. I've read several other similar stories around the internet some claim Hardware issues, other Firmware.
Anyhow, my hardware is still under warranty, but is there any way to downgrade the firmware to test? I cannot find any offical download links.
Thanks,
Josh
    • jholden's avatar
      jholden
      I've tried that firmware and several lower, down to RAIDiator 4.2.27, all of them yeild the same results. I'm convinced it's a hardware issue since no other settings have changed in the configuration.
      • StephenB's avatar
        A filling OS partition can also create this symptom.  Though often that also causes the firmware downgrades to fail.
        But if you want to check for that, you can enable ssh and tell very easily if that's the problem.
        you'd install the Enable Root SSH add-on from here: https://kb.netgear.com/24551/ReadyNAS-Add-ons-for-RAIDiator-4-2-x86?cid=wmt_netgear_organic
        Then either install putty (windows) or use terminal (mac) to ssh into the NAS over the network.  User name is "root", password is the nas admin password.
        Then enter
        df . -h
        df . -i
        and report back on the results.
        You do of course have two ethernet interfaces, so you could also try switching to the second one.
ProSupport for Business
