atai
Apr 18, 2014Aspirant
New disk installation
Hello, I have to replace a disk failed on my ReadyNAS NV; I have phisically replaced the hard disk with an other one and I now I need to add the Volume. When I go to the volume setting I don't see...
atai
Apr 19, 2014Aspirant
(a) what firmware are you running on the NAS?
RAIDiator 4.1.6 [1.00a043]
(b) how many disks were there on the NAS before, and what sizes were they? What model and size did you use for the replacement?
4
Device Description Status
Disk 1 Seagate ST31500341AS 1397 GB , 32 C / 89 F , Write-cache ON OK
this is the new disk Disk 2 Seagate ST32000542AS 1863 GB , 34 C / 93 F , Write-cache ON OK
Disk 3 Seagate ST31000340NS 931 GB , 36 C / 96 F , Write-cache ON OK
Disk 4 Seagate ST2000DM001-1CH164 1863 GB , 26 C / 78 F , Write-cache ON OK
Fan 1 2083 RPM OK
Temp 1 26.0 C / 78 F [Normal 0-60 C / 32-140 F] OK
UPS 1 Not present OK
(c) how many volumes did you have on the NAS before?
4
(d) Were you running flexraid or xraid?
No
After the reboot I have seen the new disk available for the volume creation but when I add it the system was not able to add
This is the log
Sat Apr 19 08:40:02 CEST 2014 Volume D failed to be added.
4
Fan 1 2083 RPM OK
4
No
This is the log
