atai
Apr 18, 2014Aspirant
New disk installation
Hello, I have to replace a disk failed on my ReadyNAS NV; I have phisically replaced the hard disk with an other one and I now I need to add the Volume. When I go to the volume setting I don't see...
Apr 19, 2014Guru - Experienced User
xraid and flexraid are the only two modes of operation, so you have to be running one or the other. Since you have 4 volumes, it must be flexraid.
4K sector (2 TB) drive support was added in 4.1.7. So vandermerwe is correct, you need to update your firmware and reinstall the new disk.
