AGSowjet
Oct 20, 2016Apprentice
New HDDs (as of 2016) have 2 instead of 3 screwholes on left and right side, problem with disk trays
We just upgraded our RN 104 with 2 new 8 TB disks: Seagate Archive HDD v2 8TB, SATA 6Gb/s (ST8000AS0002) They are working fine, but I was having problems fixing them to the disk tray. New HDDs se...
mdgm-ntgr
Oct 20, 2016NETGEAR Employee Retired
Archive HDDs are not recommended for use in NAS units.
Chris2309
Mar 18, 2017Aspirant
Just unwrapped the NAS 214 and 2 Seagates Ironwolf 6TB - compatible per list. Issue inserting hard disks. Reason I see now is that Seagate has 2 holes in meantime (1 top, one down)
Plastic in slider has 2 ( 1 top one middle)
This makes it impossible to insert it easily. What is NETGEARS recommendation what I should do?
Thanks.
- jak0lantashMar 18, 2017Mentor
Based on https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List, NETGEAR's recommendation is: "To mount the disk to the desktop NAS disk tray, remove the plastic mounting bracket from the disk tray and use two screws to secure the disk to the disk tray."
- AGSowjetMar 20, 2017Apprentice
As I said, HDD manufacturers have decided to remove one of the screwholes and so they did, no matter what. :D
I wonder how many PC professionals will have to find a creative solution when replacing HDDs with new HDDs in many different PC cases, NAS cases etc.
Anyway, I preferred my solution to modify the plastic bracket instead of removing it, as described above. The HDDs are very firm in place.
