Scramjet
Nov 06, 2016Aspirant
Newbie wants advice over choice.
Hi, I think I need to get a diskless ReadyNas 212, but I would welcome some advice. My immediate need is for 8Tb of capacity, so I would understand that means buying 2 x 8Tb disks shown on the C...
- Nov 06, 2016
Scramjet wrote:
However, I think that the maximum capacity of the 212 is 16Tb.
There was an upper limit of 16 TiB in the firmware, but that was removed quite a while ago. The RN100 and RN200 series can handle larger volumes than 16 TB. Though resync times will go up as the volume size increases.
Scramjet wrote:
QUESTION
Or should I get a 4 Bay model with 4x4Tb ? Does it run quiet and cool?More bays do make it easier to expand. Though you might want to leave an empty slot. That's the cheapest way to expand later. Maybe 3x6TB?
The units will run cool if you use energy-efficient disk drives (for instance WD Reds or Seagate Ironwolf). 7200 RPM drives will run hotter.
Scramjet wrote:
Finally, does anyone have any experience of the 8Tb drives in a ReadyNas? Does it run reliable, quiet and cool?I have two units (RN102 and RN202) with 8TB+6TB jbod. That's using a WD80EFRZ and a WD60EFRX. Current temps are 30C/26C
Scramjet
Thank you StephenB That's very helpful.
FramerV
Nov 07, 2016NETGEAR Employee Retired
Hi Scramjet,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- ScramjetNov 07, 2016Aspirant
Done. Thanks
