JDJeff's avatar
JDJeff
NV+ dead and need to replace
I have a NV+ with three disks in XRaid format. We had a lightening strike and the NAS is dead (despite whole house surge protector AND local surge protector...). If I buy a new ultra 4 plus can I just insert the disks into it and have my data preserved or will I need to reformat and start over?
  • StephenB's avatar
    Lightening can be nasty - if you have coax TV/broadband, it can enter that way, and bypass the surge protectors. You might check on your surge warranties though, sometimes they cover damaged equipment to some degree.
    The raid formats are not compatible, and the OS partitions aren't either. So you will need to start over.
    The ultra should wipe the disks, though some have reported seeing "corrupt root" instead. Deleting the partitions (for instance from Windows) would prevent that. BTW, you might also want to test the disks, as they may be dead too.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You would need to get another NV+ (v1 - silver chassis) to be able to migrate your array to another NAS.
    If you like instead you could try data recovery using a PC: Mounting Sparc-based ReadyNAS Drives in x86-based Linux
    Or if you have a good backup or the data is not important you could simply do what Stephen suggested above.
    mdgm-ntgr
    Actually as well as the NV+ (v1 - silver chassis) migration to other 4-bay Sparc models (e.g. 1100) would be possible.
ProSupport for Business
