hoppingdeth
Apr 13, 2013Aspirant
NV+ V2 Power Timer not working
Hi Guys
New owner of a NV+V2 after using Duos for years. Great device, but having odd problems with the power timer.
I have the timer set to come on at 7am and switch off at midnight, but it doesn't switch off and instead stays on.
Logs show "System is up" at around 7:01am each morning and at midnight shows the "System power-on scheduled for 04/13/2013 07:00" (for example), but its stays on and doesn't power down.
Any ideas?
Thanks.
Any ideas?
Thanks.
- mdgm-ntgrNETGEAR Employee RetiredWhat version of RAIDiator?
Can you download the system logs (System > Info > Download Logs), extract the zip contents and post the contents of bios_ver.log - hoppingdethAspirantHi mdgn
RAIDiator verison 5.3.7
bios_ver.log shows:
U-Boot 1.1.4 (Feb 6 2012 - 14:42:36) Marvell version: 3.4.27
Netgear version: Uboot-1_1_4-NetgearNV+V4-V1008 If U-Boot Endiannes is going to change (LE->BE or BE->LE), Then Env parameters should be overriden.. - mdgm-ntgrNETGEAR Employee RetiredCan you install 5.3.7 over the top of itself then try again.
- hoppingdethAspirantThanks for the suggestion mdgm. Tried that first thing this morning but it didn't change the behaviour I'm afraid. I set it up to come on half an hour after I did the update and shut it down, but the power timer didn't start it up. So it looks like the power timer is simply not working for me on start up or shut down.
Do you think it is faulty hardware? I've only had the server for about 2 months. Has anyone else experienced this kind of problem? - mdgm-ntgrNETGEAR Employee RetiredWhat does your bios_ver.log look like now?
- hoppingdethAspirantHi mdgm
Thanks for your help. Contrary to my reply, it does look like its working now. Shut down last night and started up this morning - ok.
bios_ver now says:
Thanks very much for your help. - mdgm-ntgrNETGEAR Employee RetiredI guess Re-installing the update must have fixed something that was corrupt in the OS.
