Charles_R
May 19, 2012Aspirant
NV+ v2 with WD30EZRX
I purchased both of the above on May 7th via a Amazon bundle (for a great price) and when I purchased them I'm 99.99% sure the drive was listed as compatible with the NV+ v2. Installation went fine and I didn't have any issues until I tried to attach a USB drive to the NV+ v2. Every time I would attempt to copy roughly 800GB to the USB drive the NV+ v2 would drop off the network more or less freezing (requires a plug pull). It was a USB 3.0 drive so I tried the USB 2.0 port as well and had the same issue. Much later on I also tried a completely different USB drive (multiple cables too) and had the same issue. Further more I have replaced the NV+ v2 thinking perhaps it was defective and still had the same issue. I also did several Factory Defaults.
So long story (some what short) I have tried numerous NV+ v2 and USB drives and every time I attempt to copy the same 800GB data the NV+ v2 crashes. It also crashes if I direct connect a PC to the NV+ v2 (via Ethernet). So it appears whenever the transfer rate is fairly high it crashes. I have transferred the data multiple times over my 100Mbps network to/from the NV+ v2 without issue. I haven't had one that I can remember...
Since the only thing I haven't replaced is the original 3TB drive (model listed above) I'm beginning to have my doubts about it. As I can't believe the behavior is normal and I'm not far from shipping everything back and calling it quits. I copied the same data to/from two low-end NAS devices without any issues and I certainly expected this guy to keep up.
So since I began questioning the drive (I have done a few check disks which report no issues) I took another look at the compatible drives at ReadyNAS.com and notice it's not on the list. I swear it was before... and it's on the list for the Duo v2 which I would think would support the same disks. Since it's not on the list I have ordered one that is and I'm going to give it a try. Which leaves me with two questions...
Thanks.
- Is having the NV+ v2 dropping from the network (only when transfering data fairly quickly) typical behavior?
Are people having the same issue with supported drives?
Thanks.
- gandalfnetAspiranthttp://www.readynas.com/?cat=19
You have to Down grade to 5.3.4 or earlier,
If you open up a ticket it will take hours of your life away for them just to tell you to replace your drives because they are NOT on the list..
I went through it all with them and finally I was the one that I told netgear the fix was go to back in the firmware to 5.3.4 or earlier. - gandalfnetAspirantLooks like one of Netgear's programmers thinks it has nothing to do with the drive but a bug in thier firmware.
viewtopic.php?f=148&t=64488 - gandalfnetAspirantHappy Days!
Looks like they fixed the large file transfer issue with 5.3.7!
I was able to stream a file while copying three 4.2 gig files with no issues!
then I transfered a 14 gig movie file from the unit and back to it with no problems!
