Chris_tian
Mar 16, 2014Aspirant
Problems backing up settings
Hello, I own a ReadyNAS 104 for some time now. Every time I want to backup my settings I get the same problem. First some general notes to my setup: I use three disks with one volume on each dis...
Mar 22, 2014Guru - Experienced User
I have confirmed that this backup fails with 6.1.6 on my RN102.
Chris tian wrote: ...I try to create a configuration backup using the webinterface via Settings -> Configuration Backup option and selecting everything but the "Everything"-option. Then if I click on "Download Configuration Archive" there is a process started that zips all configurations...
When I save the archive a new tab launches (https://rn102/dbbroker) for which chrome shows a "loading" status. After some minutes I get a gateway timeout (504 error). Some time after that the NAS locked up, and I needed to pull the plug to resolve it. Upon reboot, the OS partition usage was ok.
I didn't attempt to confirm your analysis (but have no reason to doubt it).
You should probably open an email support ticket. I'll PM a couple of people also, just to make them aware of it.
