Chris_tian
Mar 16, 2014Aspirant
Problems backing up settings
Hello, I own a ReadyNAS 104 for some time now. Every time I want to backup my settings I get the same problem. First some general notes to my setup: I use three disks with one volume on each dis...
Chris_tian
Apr 22, 2014Aspirant
That's quite possible. Thanks for the additional information. But it shouldn't be to hard to fix for someone with a little bash scripting experience. My workaround was not really a good solution (it was just the fastest) but I think within a few hours it should be possible to find something that works as originaly intended. (Either a short loop or a find or some bash magic.)
Anyway, I think that the Netgear support team now thinks about the problem and possibly has already found an easy and elegant solution.
