Retired_Member's avatar
Retired_Member
Oct 19, 2020
Problems since Wifi mesh install
Hi
I recently installed a new TP-Link Deco mesh system in my house. As my main router is no longer the management, the Deco provides a different IP address range.
Since powering on my ReadyNas, I no longer can access the data within there, I can see the shares, it powers up ok but there seems to be an issue.
Before I Take the router out of modem mode and revert back to previous setup, is anyone aware if there are issues with Readynas devices like this when setting up a Mesh wifi system?
In the log files I get this message:
I can get the logs if required. Many Thanks
for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
  • Retired_Member's avatar
    Retired_Member
    Oct 24, 2020
    So found this simple solution installing Linux reader a freeware utility, installed one of the disks into an external hard drive and it did the rest and I was able to restore to another disk with easy.
    Here is a link, I would recommend this to others https://www.youtube.com/watch?v=nIWdZ0qDD54
  • The NAS itself is not the issue.  One of two things is likely:
    You previously assigned a static IP to the NAS, which is now outside the subnet of your new mesh system.  If you can temporarily go back to the old configuration, do so and fix that.  An OS re-install will fix it, and will also change the admin password back to the default.
    OR, you added the mesh system to a router/modem provided by your service provider but did not change it to pass-through (modem only) mode, so you now have a "double NAT" condition and one device is assigning an address to the NAS and another to the other things on the network..
      Retired_Member
      Thanks for the response.
      I did add the mesh network and also changed the ISP router to Modem mode.
      I can see the readynas now has an IP from the mesh network and I can access the admin console, I can see it in RaidR but just cannot access using the UNC path...
      I will try the reset option and let you know how that goes.
      Thanks
        Retired_Member
        So it looks like that didnt work. It seems my IP was automatically assigned rather than static which is odd as I am sure when I set it up many moons ago I did set a static IP.
        Anyways I have 2 disks in an X-RAID configuration and taking each disk out to see if I can retrieve data gives me the same message in the logs.
        Does anyone know of anyway I could get these disks up and running again.
        I am not sure if this makes any difference but the NAS has been switched off for a few months now but before it was switched off it was operating ok so unsure why I have suddenly got this issue.....confused.
        The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
        Cable
        media
        backup
ProSupport for Business
