Garthadam
Aug 21, 2015Aspirant
Problems with uploading
Running Windows 10 on Sony vaio laptop. Have a rn104 device with 2*4tb drives inserted. Updated to latest firmware 6.2.5. I have created 3 subfolders to my video folder named Documentaries, Tv Shows ...
- Aug 21, 2015
Are you trying to use the web interface for this, or are you using windows file explorer.
Windows file explorer will be much faster. If Windows isn't seeing the NAS, enter \\nasname or \\nasipaddress into the address bar (using the actual name or IP address of course). The direction of the slashes is important, so pay attention to that nuance.
Aug 21, 2015Guru - Experienced User
Garthadam
Thanks. Using the ip address in windows explorer has bought up the folders so that should prove to alot quicker.
