Cyrmel's avatar
Cyrmel
Raidar 6.5.0 not finding NAS RND2000V2
Hello,
I can see my ReadyNas DU0 RND2000V2 with Raidar 4.1.3.
On the other hand, when I run Raidar 6.5.0 it cannot find it.
I disabled the firewall without success and I can ping my NAS, so no subnet problem
From the raidar 6.5 page: https://kb.netgear.com/000060718/RAIDar-6-5 it seems compatible with my NAS.
  • StephenB's avatar
    RAIDar 6.5 should be able to discover your NAS - so that is a mystery.  Did you also disable internet security software on the PC (Kaspersky or Avast)?
    As far as compatibility goes, one thing you can't do with 6.5 is convert your NAS to run FlexRAID.  That requires the older version.
    • Cyrmel's avatar
      Cyrmel
      I disabled Avast and Zone Alarm. I also use Raidar 6.1.0 but I can't found NAS. Raidar 4.1.3 find it. My Readynas use RAIDiator 4.1.7, I don't now if there is some incompatiblity with Raidar 6.X version.
      I will attemp to use raidar 6.5.0 in another PC
      • StephenB's avatar
        RAIDar 6.5 finds my legacy NAS, and the discovery protocol hasn't changed.  It would be good to try this on a different PC next.
ProSupport for Business
