Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
Kalle13
May 20, 2017Tutor
StephenB wrote:I'd try the beta myself.
Your other option is to try paid support (my.netgear.com)
I think that`s the way: First I will try the beta. If this don`t work I will have a look on the apt-get logs. Hopefully I find the failure there. In the end if this all don`t work I have to conctact the support.
Best regards
Kalle
