chopin70
Oct 10, 2020Virtuoso
Apps page is blank after a factory reset
 After a factory reset, I restored all my data from backup  Once I was done with restoring all my shares and settings + all the data, I just discovered that the apps page is blank !  I can install app...
- Oct 14, 2020
chopin70 wrote:
Ah, I never thought about it
I restored my configuration settings without reinstalling apps
The problem is that some of the configuration settings include settings for the apps (which are no longer there). That can mess things up.
chopin70 wrote:
But if some Netgear tech can give a few steps/hints to fix the issue it would be great
You could try using ssh:
# apt-get install -fy rn-dictionary freeapp-collection readynasos ca-certificates
Be careful to log in as root, using the NAS admin password.
Oct 10, 2020Guru - Experienced User
chopin70 wrote:
Since you say it is common, is there a definite fix or workaround to restore it from Netgear ?
As I've tried to say, the available apps should eventually show up on the apps page.
But in the meantime, just download and install your apps from apps.readynas.com (keeping in mind that you want to get plex directly from plex.tv).
chopin70
yeh, got it this time
Still wired why it remains blank !
