andersc
Sep 29, 2016Aspirant
ReadNAS NV+ will not power on.
ReadyNAS was shutdown to replace the UPS attached to it, but now it will not power on.
Yes, I checked the power cable, etc.
Is there any way to find out if my power supply is one of those with the known issue?
Model: ReadyNAS NV+ (RND4000)
- DaneANETGEAR Employee Retired
Hi andersc,
Welcome to the community! :)
Kindly access then read the old forum link below:
DaneA
NETGEAR Community Team
- anderscAspirant
There is nothing in that old forum message that addresses a dead power supply.
DaneA assumed the "known issue" you meant was the service action. Did you have a different "known issue" in mind? Let us know.
If your NAS serial number is in the range in the service action, then Netgear will give you a new supply even if the warranty has expired.
If not check for warranty coverage (5 years I think).
The PSU can be replaced. One option is to get a stock supply (SS-250SU for instance) and modify the pinout for the NV+. Here's a thread with a bit more information: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases/m-p/1016241#M13476
