geoldr
Dec 02, 2014Tutor
ReadyNAS 102 8TB Max
Hi guys
I have a question about the max size for my new NAS. I see on the tech spec that it is listed to support up to 8TB Max. I can only put in 2x4TB drives? I see there are 6TB drives on the market today and am wondering if I would have to get a different NAS model to support this, or will there be a firmware update to increase the max storage capacity.
What would happen if I were to put in 2x6TB drives?
- RXLuminaryRN102 does not yet support 6TB drive. Kindly check it on http://kb.netgear.com/app/answers/detail/a_id/20641.
The following Intel-based OS 6 ReadyNAS supports 6 TB drives :
RN312
RN314
RN316
RN516
RN716 - geoldrTutorI am hopeful that a firmware update will be released to support the new 6TB drive sizes in the near future.
- vandermerweMasterI think what Ixa is saying is that 6 tb drives are not currently on the HCL for the 100 series.
You could use them, but you would lose your support. Not a good idea. - geoldrTutorYes I understand that.
When I looked at the link Ixa posted, some drives were listed as "Must use with Firmware x.x or later".
So I am hopeful that Netgear will release a firmware update in the future to add support for WD RED NAS 6TB drive. - StephenBGuru - Experienced UserThe notes on the three hitachi drives are actually mistakes- carryovers from the pro/ultra lists.
AFAIK the 6 TB drives work on the RN100 series now, as long as you stay below the 16 TiB total volume size. If so, Netgear doesn't need a firmware release to support them.
In the case of the RN102, its impossible to exceed the 16 TiB volume size anyway. But as lxa/vandermere are saying, you will lose support if you use them. Seems a bit silly to me. - geoldrTutor
StephenB wrote: The notes on the three hitachi drives are actually mistakes- carryovers from the pro/ultra lists.
That's what I was wondering, if I put them in will they work? Sounds like yes. I won't be doing this just yet as I'm good with 8TB of storage for all my backups, but it's nice to know that they should work.
You guys are very fast to respond! Thank you! - StephenBGuru - Experienced UserWell, do keep in mind the implications of no support. When you do get to the point where you need the space, research it here before you purchase the drives.
I haven't tried them myself, but my understanding is that they will work as long as the total volume size is 16 TiB or less. - vandermerweMasterI would also figure out the financial cost of upgrading to 6 tb drives versus selling the 102 and getting a 104 and sticking with the 4 tb drives you have, adding as you need more space.
A 104 is much cheaper than a 6 tb drive.
In fact, for just a little bit more than the cost of two 6 tb drives, you could get a 314 and another 4tb drive. Sell your 102 and you'll probably be no worse off.
I know it's a backup nas, but are you running 2 separate volumes or a single raid0 volume? - StephenBGuru - Experienced User
Costing out your options is always a good idea. Replacing working drives with new larger ones sometimes isn't the cheapest path.vandermerwe wrote: I would also figure out the financial cost of upgrading to 6 tb drives versus selling the 102 and getting a 104 and sticking with the 4 tb drives you have, adding as you need more space.
Here in the uk, a 104 is much cheaper than a 6 tb drive.
Though he doesn't need the space now, so I think this all a "what if" for the future. Prices will undoubtedly change. - geoldrTutor
Exactly. This is more of a "what if" for me. But I definitely did look into that option.
Having said that, I got the 102 on a sale for $60 (with a $20 mail in rebate), so that saves me a lot from going retail pricing.
