dellwilson's avatar
dellwilson
ReadyNAS 102: Any issues with 3TB drives?
Hi all,
I have a ReadyNAS 102 with two WD 1TB drives, but I'm getting close to full and want to upgrade to 3TB HDDs. I see a lot of discussions here about the 102 and 2TB drives, but not 3TB. Is there any problem with 3TB drives on the 102?
Thanks
Dell
  • 3 TB works fine, I've had WD30EFRX in mine for quite some time (2 1/2 years for the first drive).
    I recommend NAS purposed drives (in the case of WD, that would be RED or RED Pro).
  • StephenB's avatar
    • dellwilson's avatar
      dellwilson
      Thank you very much for your quick response.
      I was considering Seagate Barracuda versus the WD Red as they are about $20 less at 3TB, but I've seen several discussions waving off the Barracuda. I'll take your advice and go with the WD Red.
      • StephenB's avatar
        I haven't seen any issues with the Seagate VN drives posted here, but lots of folks have had problems with the DMs.
ProSupport for Business
