JordanThompson's avatar
Apr 18, 2016
ReadyNas 104 with two 2TB drives cannot recognize 4TB drive via eSATA or USB (front or back)
Hi all,
I have  a ReadyNAS 104 (100 with 4 bays).  It currently has two 2TB drives in it in a XRAID.  They are both synchronized.
I want to use a 4TB drive connected to a Vantec NexStar (connected via either USB or eSATA) to backup the ReadyNAS.
I am able to connect the NexStar to my PC via either eSATA or USB (front or back) and I can see the drive.  When I connect it to the ReadyNAS I go to the System page to look for it (as shown here) and its not visible.
My ReadyNAS is running version 6.4.2
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Please send in your logs (see the Sending Logs link in my sig)
        mdgm-ntgr
        Thanks for the logs.
        Was the disk connected to the NAS at the time you downloaded the logs and if so to which port?
ProSupport for Business
