Wrightshouse
Jul 25, 2021Aspirant
ReadyNAS 202 factory reset
I have "inherited" a ReadyNAS 202 (6TB) from a friend who has sadly passed on. I am attempting to reset the entire unit to factory settings following the guidance in the OS6 Software and RN202 Hardware Manual. I am having no luck. I hold the reset button and power on, continuing to hold reset. The power light blinks. Disk 1 and 2 come on simultaneously for maybe 2 seconds. They go off. Shortly, they come on together again and again go off. In a few seconds the disk 2 light comes on so I now have power blinking blue and disk 2 on solid. That's it. I could wait for hours, nothing changes. Backup never comes on and all lights do not come on together. According to the manual, what I'm seeing is a memory test that may last 8 hours. This makes no sense.
Here's the detail:
Any help welcome.
Your screenshot says otherwise - it says you have a ReadyNAS Duo (v1). It can't handle drives larger than 2 TB, so with RAID-1/XRAID you'll have a 2 TB volume, not 6. One other restriction is that is uses SMB 1. It's an old model - Netgear stopped shipping it in late 2011.
Manuals are here:
- https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- https://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
Did your friend possibly have more than one ReadyNAS?
- WrightshouseAspirant
Manuals are here:
Thank you for the reply! That's a great catch. Actually he had 2. I have them both. This one was packed in a box marked "6TB"... I'll bet that's actually the other one. I'll see if that one matches the instructions I found and I'll try the manual links you sent as well for the 1st one. I just want to update these and start fresh. Thanks!
Wrightshouse wrote:
I just want to update these and start fresh. Thanks!FWIW, there are two other ways to do that.
If you know the NAS admin password, there is a control in both NAS that will do the factory default from the NAS web ui. Let me know if you need help finding those.
You can also zero the disks (or remove the partitions) in a Windows PC. Then power up with the unformatted drives, and both NAS will automatically do a factory install.
All the information is saved on the disks - a factory default formats/partitions the drives, and installs a linux OS on a small partition on the disks. From there, the system boots from the disks.
