tkevans
Aug 05, 2022Apprentice
ReadyNAS 204; Check for Update Fails
Last couple of days, my ReadyNAS 204 (firmware 6.10.7) has begun failing the "check for update" function. Returns "60010100060 Communications Error. Check your internet connection, DNS settings, or...
Aug 05, 2022Guru - Experienced User
tkevans wrote:
Last couple of days, my ReadyNAS 204 (firmware 6.10.7) has begun failing the "check for update" function. Returns "60010100060 Communications Error. Check your internet connection, DNS settings, or proxy settings."
I'm seeing the same error, so it must an issue on Netgear's end.
- Jul 31, 2022Retired_Member
