tkevans
Aug 05, 2022Apprentice
ReadyNAS 204; Check for Update Fails
Last couple of days, my ReadyNAS 204 (firmware 6.10.7) has begun failing the "check for update" function. Returns "60010100060 Communications Error. Check your internet connection, DNS settings, or...
tkevans
Aug 11, 2022Apprentice
This problem has now disappeared for me. Nothing from NetGear, but my 'check-for-update' is now working properly with no error messages. Thanks.
- StephenBAug 11, 2022Guru - Experienced User
Not sure what you mean by that, since they did post here saying that they were working on it, and then followed up saying it was fixed.
- tkevansAug 11, 2022Apprentice
Nothing posted in this thread. Perhaps somewhere else? At any rate, all's well that ends well.
- Jul 31, 2022Retired_Member
