tkevans
Aug 05, 2022Apprentice
ReadyNAS 204; Check for Update Fails
Last couple of days, my ReadyNAS 204 (firmware 6.10.7) has begun failing the "check for update" function. Returns "60010100060 Communications Error. Check your internet connection, DNS settings, or...
RunarH
Sep 14, 2022Aspirant
Same problem, but firmware 6.10.6.
Have updated one of two but one of them vil not update
- StephenBSep 14, 2022Guru - Experienced User
Actually a different problem, since the original one was caused by an issue on Netgear's end that caused all check-for-updates to fail on all ReadyNAS. FWIW, it is working on born an RN102 and an RN526 that I checked.
Have you confirmed that the problem NAS can reach the internet?
- Jul 31, 2022Retired_Member
