jwilkens's avatar
jwilkens
ReadyNAS 204 Ethernet Ports nor working
Good day,
I need some help, I have a ReadyNAS 204 which has been working perfectly since I bought it about a year ago, but after struggling to connect to it I found that none of the lights on either of the LAN ports come on.  Is it possible to access the the ReadyNAS directly from a PC without using the LAN connection?  Alternatively how do I recover the data currently on the system?
  • There is no way other than the ethernet connection to access the data.  There are ways to recover the data from the drives using a PC and a Linux LIve CD.  But unless you are not the original purchaser, your unit is still under warranty, so why mess with it?
    • jwilkens's avatar
      jwilkens
      Thank you,
      I am the original purchaser and will return it, but I urgently need to access the data and can't wait for the replacement or repair to be done.
      • StephenB's avatar
        Are you comfortable with Linux shell commands?
ProSupport for Business
