kncowans's avatar
kncowans
Virtuoso
Apr 14, 2018
Readynas 214 compatible with the WD Red 10TB HDD?
Hello all
I am looking to upgrade the storage in my RN214 which currently has WD RED 5TB HDDs.
I was looking at the WD RED 8TB HDD but noticed there is now a 10TB RED, however the 10TB RED is not shown on the HDD Compatibility List for the RN214.
Since it is the same family of HDD I assume it should be compatible, however I would like to confirm compatibility first.
Does anyone know if the 10TB RED is compatible with the RN214?
Thanks in advance
Kevin
  • StephenB's avatar
    As you suggest, it should work.  But I haven't seen any posts here from folks using this drive.
    • kncowans's avatar
      kncowans
      Virtuoso
      Hello Stephen
      Thanks for the reply.
      Is there any way to contact Support with this query that would not require a charge?
      Thanks in advance
      Kevin
      • StephenB's avatar
        Not that I know of.  They don't do the disk certification themselves, so the most they could do is forward your query.
        douglas_cheung - any chance that these disks will be certified in our lifetimes?  :smileywink:
  • Hello Kevin - did you end up finding the answer to your question? I have the ReadyNAS 214 and I want to install the WD Red 10TB (5400) drive so was curious if that worked for you. Thanks.
    • kncowans's avatar
      kncowans
      Virtuoso
      Hello
      Unfortunately I have not been able to find any answer to this question.
      I have decided to hold off on upgrading my HDD until I can get a clear answer.
      Sorry I could not of more help.
      Kevin
      • n0Ob's avatar
        n0Ob
        Thank you, for your prompt response. I have been reading the stats on device reliability, and I think 10TB is still too "new" to be using. I might just go with the 8TB to be on the safe side.
        I'll let you know if I find something new on the 10TB drive compatibility with the RN214.
ProSupport for Business
