basysaz
Sep 12, 2016Tutor
ReadyNAS 312 disk trays
Am I missing a trick with the 312 disk trays? Hard drives won't just snap in and "instructions" are useless. The trays that came with the unit have posts on a 3-sided plastic insert that would ...
mdgm-ntgr
Sep 13, 2016NETGEAR Employee Retired
We have a video on this:
We also have instructions in the Hardware Manual and in the KB:
http://kb.netgear.com/app/answers/detail/a_id/22894/~/readynas-os-6%3A-adding-a-disk-to-desktop-models
- StephenBSep 13, 2016Guru - Experienced User
Note that the plastic inserts can be removed - and use mounting screws in the bottom of the tray (just like the NV+). That's also in the instructions.
You need to remove them with 2.5" drives. Also, some disks (notably 8-10 TB models) don't have center holes in the right position for the plastic inserts.
If you do need to remove them, it's good to store them for future use.
