gazgaz's avatar
gazgaz
readynas 716x failed after attempt to upgrade hard drives from 6tb to 8tb
Hi all I have failure go access all info on my readynas after I stared to upgrade the disks from wd 6tb to wd 8tb hard drives
pulled one and replaced - info degraded
overnight seemed to repair
pulled second and replaced - info degraded
pulled third one and replaced - info degraded
but one of the other 6 tb had a red light
so pulled and replaced
just said new disk
now have no access to info
can I put all the original discs in and reboot ?
30 tb of info needed
    Likely not, unless there were not files written to the volume over the several days you were upgrading.  The expansion would probably get in the way too.
    you should probably contact support - you might need data recovery.
  • StephenB's avatar
    • gazgaz's avatar
      gazgaz
      Ok
      Thanks for the advice Stephen
      I packed it up and sent it away to the specialists to see if they save anything
      Gary
ProSupport for Business
