LanceWright
Mar 20, 2016Aspirant
ReadyNAS and Cloud not acting consistently
Hello. I am running a ReadyNAS 100. It seems to appear on the network, but configuring things seems a bit inconsistent. For example, I've added my name to be an account. But, when I atte...
BrianL2
Mar 20, 2016NETGEAR Employee Retired
Hi LanceWright,
Welcome to the community!
Kindly check this article and see if it helps.
Kind regards,
BrianL
NETGEAR Community Team
LanceWright
Apr 17, 2016Aspirant
Thank you.
I'm still having problems.
I'm following the Netgear instructions, but the system is not behaving (at all) in the way that Netgear is saying it should be working.
I am currently getting the following message:
"Currently you have no registered or shared devices.
Go to Discover page to register your ReadyNAS device, or if you have a router with ReadyCLOUD support, browse http://routerlogin.net, go to ADVANCED>USB Functions>ReadyShare Storage>REadyCLOUD to register your router."
I click on http://routerlogin.net, and get the following message:
Safari Can't find the Server
I only have the Netgear NAS device, so I am confused as to manage, create and endit ReadyCLOUD users, etc.
What am I missing?
- BrianL2Apr 17, 2016NETGEAR Employee Retired
Hi LanceWright,
Could you tell us if you have green check marks for both internet and services under the Cloud tab (in the local admin page)? Also, tell us if you were able to create a ReadyCLOUD account. If yes, send me a PM together with the username or the e-mail address that you've used.
Looking forward to hear your response.
Kind regards,
BrianL
