dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description
This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to USB cable.
Advantages:
* VMware player be downloaded freely
* Can run in both existing linux / MS Windows (XP,Vista etc) operating system without any further modification
Disadvantages:
* Requires a SATA to USB cable
* Mac users will need to find another program to run the VMware files
Background
At some point your ReadyNAS Duo unit is going to stop working (which hopefully will be long and far into in the future) and there may be a point where you'll need to rely on your external backups.
While it's a good strategy to ensure you (and your family / clients) have a good disaster recovery process (having external off-site backups, checking the backups, knowing how to restore from backups etc), in some cases the backups might not work or the backups aren't available to you.
Due to the architecture of the ReadyNAS Duo (more specifically the 16KB blocksize of the partitions), you cannot simply pull out the hard disks, place them into a standard windows / linux pc, then copy all your files across to another computer or storage device.
Unfortunately there are no windows drivers that can properly access the drives and the process to configure a linux pc is complex (see viewtopic.php?f=25&t=24861&hilit=16+blocksize for further background on this)
The following VMware images contain all required patches to read your HDDs in linux just by entering a few terminal commands.
VMplayer Link
To get started, you will need to download a version of VMplayer for your operating system Win/Linux (Mac not directly supported yet), this can be found
http://www.vmware.com/products/player/
VMware Linux Image with Ext2Fuse
acmtn Debian release - tested ok, reports are that it works fine except for files greater than 4GB)
http://www.readynas.com/contributed/dek ... ebian5.zip
acmtn VM login info (username/password): root/rootadmin, vmuser/vmuser1
(please read the forums for more details on how to use this vmware )
_vito Ubuntu release - currently being tested, enables you to use the HDDs directly plugged into your pc without the need for a SATA to usb cable.
http://www.readynas.com/contributed/dek ... buntu9.rar
Details on this alternative vmware can be found on this post (you'll need to review the instructions carefully):
viewtopic.php?p=203653#p203653
dekkit Debian release - tested, a number of issues.
my initial attempt that helped start this thread has been found to have quite a few issues and may not work for you, but can be found here if you would like to try:
http://www.readynas.com/contributed/dekkit/VMwareDebian5.0%20-%20ext2Fuse.rar
dekkit VM login info: User: vmplanet pass: vmplanet.net
the acmtn version at this stage appears to be getting more reliable results for users. Unfortunately, I have not had time improve on my original dekkit release due to time constraints but if you would like to try please post your results.
Dekkit release Notes:
* You will need 8GB of free disk space once you have uncompressed the image
* You will still need to execute some of the terminal commands to mount the drive (take precaution so you don't accidently blow away your data)
* This VMware can access other windows file shares and can also be configured to host windows shares (see the docs for debian for more info on this)
* To uncompress the file use WinRar: http://download.cnet.com/WinRAR-32-bit/ ... 07677.html or for non-windows platforms try: http://www.rarlab.com/download.htm
* This image is a work in progress (WIP) so please post all errrors !!!!!.
Dekkit release Usage- this may apply to the other versions (eg acmtn
Login to the OS
Access the terminal and enter the following once the HDD has been attached (take note that your /dev/c may differ):
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
ext2fuse /dev/c/c /mnt/lvm
there is a delay in output but then ..
"/dev/c/c is to be mounted at /mnt/lvm
fuse-ext2 initialized for device: /dev/c/c
block size is 16384"
Dekkit Release Acknowledgements
The original VMware image was found http://www.vmplanet.net/node/85 (before the various patches were applied - so feel free to drop them a donation), if you can improve this image by way of a script to make it even easier to use for us 'non-linux users' then please do so and share it back with the rest of us
Advantages:
Disadvantages:
Background
VMplayer Link
Login to the OS
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
- acmtnAspirant
giob wrote: acmtn,
I just started downloading your image from your ftp, but only at 1 kB/sec!
Or could you upload it somewhere else?
Thanks
Updated info: ftp site is [removed], you can use anon login. mulitpart is posted and ready. single file is still uploading and should be ready by 1am Pacific on 01/04/10. - giobAspirantThanks,
I downloaded multipart files but could not extract them with 7zip (error in archive). I will wait for the singlefile and try again tomorrow.
Giob - acmtnAspirant
giob wrote: Thanks,
Giob
I downloaded and tested the zip files with WinZip (which is what they were created with) and had no issue. - pingleAspirantHi acmtn
I used a terminal to make an anonymous connection to your ftp site, and found the directory structure public/vm_Debian5_ext2fuse/singlefile as well as public/vm_Debian5_ext2fuse/multipart.
Unfortunately it looks as though the singlefile directory does not have access permissions for anonymous users.
Regards, Peter - acmtnAspirant
pingle wrote: Hi acmtn
Regards, Peter
Permissions on the single file fixed. Also added versions created with WinRAR - not sure if it makes a difference for the people having difficulty with .zip files, but I kinda want to put this to bed for myself. Will be taking down the site at the end of the week, so hopefully someone can get them copied off to a more permanent location. Thanks, Adam. - _vitoAspirant
giob wrote: _vito,
could you post instructions on how to use and compile ext2fuse 0.5 in Linux?
I have the same "fuse-ext2: Can't read an inode bitmap while reading inode bitmap" error.
Thank you
(If you are italian we could exchange private mails)
giob,
I just follow the instructions for all the packets as root:
./configure
make
make install
Anyway ext2fuse 0.5 is already compiled and the command is
ext2fuse -n /dev/c -m <mount_point>
as root. - giobAspirantactmon,
singlefile vmw.Debian5.rar has still permission problems, now I am downloading the zip one. Thanks
giob - dekkitAspirant
acmtn wrote: pingle wrote: Hi acmtn
Regards, Peter
yep these will be put on the readnas forums server. i'll be uploading it as as soon as my internet usage quota is reset. - pingleAspirantThank you acmtn. :worship:
I have downloaded your singlefile, unzipped, booted up in VMWare Fusion on my Mac and successfully accessed the VM.
In the VM I opened up a terminal as root and followed the command line instructions as posted by dekkit at the beginning of this post.
Wahoo - I did not get the inode error. :D
When the terminal said "block size is 16384", it did not return to the cursor.
However, I opened up a new terminal as root and was able to view all of my files.
The next stage was to copy required files off the old disk.
I had a slight complication, in that a large number of the file names (in the source directory and in subdirectories) contained spaces.
This was also the case in the target directory of the USB disk I was copying to (I wanted to only copy those files/directories that did not already exist).
The old disk was not visible through the desktop, as the desktop had vmuser permissions, not root.
Repeated variations of command line hocus pocus were unsuccessful, but using 'startx -- :1' (thanks, Roxoff@www.linuxforums.org/forum) I was able to start a root permissions GUI to drag and drop the files.
I've not bothered with the few files that are > 4GB, as it's apparent that the VM with the compiled-in ext2fuse needs to be recompiled with large file support (beyond my capability).
For the edification of other users on this forum, my problem was not a hardware issue (and anyway, my Duo is out of guarantee) - the problem was the partition that is used by Netgear to store all of the configuration data became corrupted - i.e. my data was fine, but the NAS was no longer operable - even a firmware reload did not fix it.
My only alternative was a factory reset, blitzing my data (and my backup process wasn't optimal).
Thanks to the efforts of acmtn, dekkit et all I have now been able to recover my data.
Best regards, Peter - acmtnAspirantHello, unless I hear otherwise, I will taking my ftp site down this Friday the 15th. Thanks.
